跳转到主内容
Dell Inspiron E1705 RAM Replacement
你所需要的
  1. Dell Inspiron E1705 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
    Introduction: Parts: Need to add the Fan Part Numbers
    Original equipment: CPU Fan DC28A000820, GPU Fan DC28A000920
    John Frazier - 回复
  2. Dell Inspiron E1705 RAM Replacement: 步骤 2 中的图像 1,2 Dell Inspiron E1705 RAM Replacement: 步骤 2 中的图像 2,2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Dell Inspiron E1705 RAM Replacement, RAM: 步骤 3 中的图像 1,2 Dell Inspiron E1705 RAM Replacement, RAM: 步骤 3 中的图像 2,2
    • Turn the computer over, screen closed, so that the underside is showing
    • Locate the two screws as shown and remove them.
    • Use a small phillips head screwdriver
  4. Dell Inspiron E1705 RAM Replacement: 步骤 4 中的图像 1,3 Dell Inspiron E1705 RAM Replacement: 步骤 4 中的图像 2,3 Dell Inspiron E1705 RAM Replacement: 步骤 4 中的图像 3,3
    • Remove plastic cover carefully
    • There will be two RAM sticks as shown
    • Using your fingers, pull the sides apart that are holding the RAM in place. This will release the RAM.
  5. Dell Inspiron E1705 RAM Replacement: 步骤 5 中的图像 1,1
    • Carefully remove old/damaged RAM sticks and replace with new ones.
结论
5等其他人完成本指南。
Evan Fairchild
于10/05/10注册
613 声望
创作了4篇指南
团队
Cal Poly, Team 22-5, Maness Fall 2010 Cal Poly, Team 22-5, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G5
4 名成员
创作了11篇指南
一条评论
If upgrading RAM, a black DOS based screen will show stating "the amount of RAM in system has changed", wait 1minute and the computer will beep and prompt for F1 (boot normally) or F2 (run system setup utility). Pressing F2 and waiting some time will allow the computer to reconfigure and then boot into Windows normally.
bejtommywy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 8,129
