本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will be very important for other guides, as it gives you access to the inner parts of your computer.
你所需要的
Remove the 12 Phillips #1 screws from the edges of the lower case.
You may also need to remove the central screw next to the lock icon.
Using a Phillips head screwdriver, remove the screws shown in the image. They all have the letter "P" next to them.
Carefully unplug the connections shown.
Also, the wireless cables on the right side may prevent moving the upper case out of the way.
Once the screws have been removed and the connections unplugged, use the plastic opening tool to gently separate the panel from the lower case.
2等其他人完成本指南。
