跳转到主内容
Dell Inspiron E1705 Battery Replacement
  1. Dell Inspiron E1705 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron E1705 Battery Replacement: 步骤 2 中的图像 2,2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
结论
To replace your battery, follow these instructions in reverse order.
5等其他人完成本指南。
Malik Shahbal
于10/05/10注册
471 声望
创作了5篇指南
团队
Cal Poly, Team 22-5, Maness Fall 2010 Cal Poly, Team 22-5, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G5
4 名成员
创作了11篇指南
一条评论
I think it would be complete if we knew where to buy it as well.
Nobody would read up on changing a battery if he didn’t need one, so you might as well tell him where to get it.
I think that makes sense. However thank you for your effort.
kjanmunkedal - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 4,239
