本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Before any work can be done ensure that the laptop is powered off.
Use either the power button on the computer or issue a shutdown from the operating system.
Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
On the back of the laptop there is a compartment for the modem for easy access.
It is located right above the switch for the battery and has two phillips head screws as well as a sticker for the laptops product key.
Unscrew the two screws with a screwdriver and lift the backplate up to unveil the Modem.
Installing a new modem: Line up the new modem by making sure the slot where the modem is installed lines up with the position of the connector on the new modem.
Push the modem down. Make sure to do this evenly so the modem makes a good connection.
Repeat this procedure until the modem is secure.
