跳转到主内容
Dell Inspiron E1405 LCD Screen Replacement
你所需要的
  1. Dell Inspiron E1405 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 LCD Screen Replacement: 步骤 2 中的图像 1,3 Dell Inspiron E1405 LCD Screen Replacement: 步骤 2 中的图像 2,3 Dell Inspiron E1405 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 1,3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 2,3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 3,3
    • Use your fingers or a spudger to remove the six small rubber covers off the display assembly.
    • Remove the six 5.7 mm screws with a Phillips #00 screwdriver.
  4. Dell Inspiron E1405 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Use your fingers to gently pry the front bezel off the display assembly. Start at a corner and work your way around.
    • Remove the front display bezel when it comes free.
  5. Dell Inspiron E1405 LCD Screen Replacement: 步骤 5 中的图像 1,3 Dell Inspiron E1405 LCD Screen Replacement: 步骤 5 中的图像 2,3 Dell Inspiron E1405 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Remove the three 3.6 mm screws using a Phillips #00 screwdriver on both sides of the display.
    • Remove the LCD screen from the display assembly.
  6. Dell Inspiron E1405 LCD Screen Replacement: 步骤 6 中的图像 1,2 Dell Inspiron E1405 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Unplug the VGA cable by pushing the two metal sides towards the middle of the strip.
    • Gently pull the VGA cable away to release the strip.
  7. Dell Inspiron E1405 LCD Screen Replacement: 步骤 7 中的图像 1,2 Dell Inspiron E1405 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the next connection by pressing the two metal sides towards the middle. Then gently pull up the ribbon.
结论
另外一个人完成了本指南。
团队
Texas Tech, Team S8-G3, Bennett Spring 2017 Texas Tech, Team S8-G3, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G3
3 名成员
创作了5篇指南
一条评论
I need complete body *Dell INSPIRON E1405 .
St Master Fun - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 471
