简介
The disk drive lets you install drivers from disks and many other useful things. This is a simple replacement and should only be done if there is no way the disk drive could ever operate correctly.
你所需要的
Remove the battery by flipping the two switches under the battery and pulling it out
Remove the 8mm screw
Use the plastic opening tool to push out the disk drive.
Pull the disk drive out with the opposite hand.
即将完成!
结论
