跳转到主内容
Dell Inspiron 9300 Trackpad Replacement
你所需要的
  1. Dell Inspiron 9300 Trackpad Replacement, Trackpad: 步骤 1 中的图像 1,1
    • Remove the battery in to order avoid damaging internal components.
  2. Dell Inspiron 9300 Trackpad Replacement: 步骤 2 中的图像 1,1
    • Remove the twelve 6mm Phillips case screws from the bottom of the case.
  3. Dell Inspiron 9300 Trackpad Replacement: 步骤 3 中的图像 1,1
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • Start on the right hand side, where there is a notch in the bezel for easiest removal.
  4. Dell Inspiron 9300 Trackpad Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 9300 Trackpad Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 9300 Trackpad Replacement: 步骤 4 中的图像 3,3
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard
  5. Dell Inspiron 9300 Trackpad Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 9300 Trackpad Replacement: 步骤 5 中的图像 2,2
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
  6. Dell Inspiron 9300 Trackpad Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 9300 Trackpad Replacement: 步骤 6 中的图像 2,2
    • Remove the seven 6mm Phillips scres holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger
  7. Dell Inspiron 9300 Trackpad Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 9300 Trackpad Replacement: 步骤 7 中的图像 2,2
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger
    • Remove the trackpad ribbon cable from the motherboard using a spudger
  8. Dell Inspiron 9300 Trackpad Replacement: 步骤 8 中的图像 1,1
    • Pull up and away on the uppercase to remove.
结论
Steven Faulkner
于09/26/16注册
214 声望
创作了2篇指南
团队
USF Tampa, Team 16-6, Eyestone Fall 2016 USF Tampa, Team 16-6, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S16G6
5 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 172
