跳转到主内容
Dell Inspiron 9300 Modem Replacement
你所需要的
  1. Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: 步骤 1 中的图像 1,3 Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: 步骤 1 中的图像 2,3 Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Flip the computer over and place it on a clean level surface.
    • Loosen the screws using a size #0 Phillips screwdriver.
    • The screws do not come completely out.
    • It is strongly recommended that the Anti-Static Wrist Strap is used to avoid damage to internal components.
  2. Dell Inspiron 9300 Modem Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 9300 Modem Replacement: 步骤 2 中的图像 2,2
    • Once the screws are loose, open the panel using a plastic opening tool to access the components below.
    • The modem card should be labeled MODEM. The WIFI card is larger than the modem and closer to the outer edge of the computer.
  3. Dell Inspiron 9300 Modem Replacement, Modem Card: 步骤 3 中的图像 1,2 Dell Inspiron 9300 Modem Replacement, Modem Card: 步骤 3 中的图像 2,2
    • Remove the screw holding the card in place using a size #0 Phillips screwdriver.
    • Gently unplug the card from the connecting black wire using a black spudger.
    • The modem can now be safely removed.
结论
Randy McMillan
于09/21/16注册
738 声望
创作了4篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,516篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 200
