当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Undo the screw on the Mini-PCI card cover labeled "C"
This screw will remain within the panel
Remove the panel from the chassis.
Use your fingertips to carefully spread apart the white plastic tabs.
Flip the Mini-PCI card up at a 45 degree angle.
Remove the card from the computer by sliding out diagonally
Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
