简介
This guide requires a Phillips #00 screwdriver
配件
无需配件。
  1. Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  4. Undo the screw on the Mini-PCI card cover labeled "C" This screw will remain within the panel
    • Undo the screw on the Mini-PCI card cover labeled "C"
    • This screw will remain within the panel
    • Remove the panel from the chassis.
  5. Disconnect the antenna cables from the Mini-PCI card.
    • Disconnect the antenna cables from the Mini-PCI card.
  6. Use your fingertips to carefully spread apart the white plastic tabs. Flip the Mini-PCI card up at a 45 degree angle. Remove the card from the computer by sliding out diagonally
    • Use your fingertips to carefully spread apart the white plastic tabs.
    • Flip the Mini-PCI card up at a 45 degree angle.
    • Remove the card from the computer by sliding out diagonally
    • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
结论
另外一个人完成了本指南。
charlierefvem
于2011年01月11日注册
854 信誉积分
创作了7篇指南
团队
Cal Poly, Team 13-2, Forte Winter 2011 Cal Poly, Team 13-2, Forte Winter 2011 的会员
CPSU-FORTE-W11S13G2
5 名成员
创作了8篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 9
总计 4,002
