跳转到主内容
Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement
你所需要的
  1. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: 步骤 1 中的图像 3,3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: 步骤 2 中的图像 3,3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Mini-PCI (WiFi) Card: 步骤 3 中的图像 1,2 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Mini-PCI (WiFi) Card: 步骤 3 中的图像 2,2
    • Undo the screw on the Mini-PCI card cover labeled "C"
    • This screw will remain within the panel
    • Remove the panel from the chassis.
  4. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: 步骤 4 中的图像 1,1
    • Disconnect the antenna cables from the Mini-PCI card.
  5. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: 步骤 5 中的图像 3,3
    • Use your fingertips to carefully spread apart the white plastic tabs.
    • Flip the Mini-PCI card up at a 45 degree angle.
    • Remove the card from the computer by sliding out diagonally
    • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
结论
另外一个人完成了本指南。
charlierefvem
于01/11/11注册
854 声望
创作了7篇指南
团队
Cal Poly, Team 13-2, Forte Winter 2011 Cal Poly, Team 13-2, Forte Winter 2011 的会员
CPSU-FORTE-W11S13G2
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 4,267
