当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M."
This screw will remain in the panel.
Pull the cover away from the laptop using your finger.
Use your fingertips to carefully spread apart the plastic white tabs.
Flip the RAM up at a 45 degree angle and remove it.
Hold the RAM by the edges only.
Ground yourself while dealing with RAM. Static shock can damage the memory. Store the RAM in an anti-static bag while it is not in use.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
