跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide requires a Phillips #00 screwdriver
配件
没有特定配件。
  1. Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  3. Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  4. Undo the two screws on the fan cover plate labeled "F3", they will remain in the panel. These screws will remain in the panel Lift up on the side of the fan nearest the screws to release the fan module
    • Undo the two screws on the fan cover plate labeled "F3", they will remain in the panel.
    • These screws will remain in the panel
    • Lift up on the side of the fan nearest the screws to release the fan module
结论
charlierefvem
于2011年01月11日注册
854 信誉积分
创作了7篇指南
团队
Cal Poly, Team 13-2, Forte Winter 2011 Cal Poly, Team 13-2, Forte Winter 2011 的会员
CPSU-FORTE-W11S13G2
5 名成员
创作了8篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,879
