1. Locate the release tabs located on either side of the battery, on the bottom of the laptop
    • Locate the release tabs located on either side of the battery, on the bottom of the laptop
    • Push the release tabs toward the center of the device.
    • Remove the battery.
  2. Remove the two countersunk keyboard screws using the Phillips #00 screwdriver
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver
    • Battery removal is not necessary for keyboard removal.
  3. Lift up the keyboard using your fingers or a plastic opening tool
    • Lift up the keyboard using your fingers or a plastic opening tool
    • Do not not tear the ribbon cable hidden behind the keyboard
    • Disconnect the cable by sliding the connector ears outward
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. After removing the keyboard, use the plastic opening tools or other form of leverage to remove the rest of the silver casing
    • After removing the keyboard, use the plastic opening tools or other form of leverage to remove the rest of the silver casing
    • Depending on your model, there could still be some hidden screws on the bottom case of the laptop that hold the palm-rest in place.
  6. Use a plastic opening tool to pry the silver portion front of the top away from the colored portion.
    • Use a plastic opening tool to pry the silver portion front of the top away from the colored portion.
  7. There should be two small screws to the bottom corners of the speaker assembly, which can be found below the screen. Unscrew them.
    • There should be two small screws to the bottom corners of the speaker assembly, which can be found below the screen. Unscrew them.
    • NOTE: Keep track of where you put the screws after you remove them. Keep screws of the same size together and away from screws of different sizes.
  8. There should be a cable coming off the speakers that connects to the base below the keyboard. It should easily slide out from here. Congratulations! You have successfully removed the speakers.
    • There should be a cable coming off the speakers that connects to the base below the keyboard. It should easily slide out from here. Congratulations! You have successfully removed the speakers.
结论
3等其他人完成本指南。
Kyle Beekman
于2012年04月05日注册
144 信誉积分
创作了6篇指南
团队
Cal Poly, Team 14-10, Forte Spring 2012 Cal Poly, Team 14-10, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G10
5 名成员
创作了7篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 1,233
