跳转到主内容
Dell Inspiron 910 Speaker Replacement
你所需要的
  1. Dell Inspiron 910 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Speaker Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
  3. Dell Inspiron 910 Speaker Replacement: 步骤 3 中的图像 1,1
    • Lift up the keyboard using your fingers or a plastic opening tool.
    • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
    • Disconnect the cable by sliding the connector ears outward.
  4. Dell Inspiron 910 Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • After removing the keyboard, use the plastic opening tool or other form of leverage to remove the rest of the silver casing.
    • Depending on your model, there could still be some hidden screws on the bottom case of the laptop that hold the palm-rest in place.
  5. Dell Inspiron 910 Speaker Replacement: 步骤 5 中的图像 1,1
    • Use a plastic tool to carefully pry the silver portion front of the top away from the colored portion.
  6. Dell Inspiron 910 Speaker Replacement: 步骤 6 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the two small screws at the bottom corners of the speaker assembly.
    • Keep track of where you put the screws after you remove them. Keep screws of the same size together and away from screws of different sizes.
  7. Dell Inspiron 910 Speaker Replacement: 步骤 7 中的图像 1,1
    • Slide out the cables connected to the speakers and the base below the keyboard.
    • Remove the speakers from the laptop.
结论
3等其他人完成本指南。
Kyle Beekman
于04/05/12注册
144 声望
创作了6篇指南
团队
Cal Poly, Team 14-10, Forte Spring 2012 Cal Poly, Team 14-10, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G10
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 17
总计 1,561
