跳转到主内容
Dell Inspiron 910 Solid-State Drive (SSD) Replacement
你所需要的
  1. Dell Inspiron 910 Solid-State Drive (SSD) Replacement, Remove screws from SSD: 步骤 1 中的图像 1,1
    • "CAUTION"If you remove the solid-state drive from the computer when the drive is hot, do not touch the solid-state drive
    • Remove the two screws that secure the solid-state drive.
    • Lift the solid-state drive out of its system board connector.
    • Insert the solid-state drive into the slot at a 45-degree angle.
    • Press the solid-state drive down and replace the two screws that secure the drive.
    • Replace the module cover
    • Slide the battery into the battery bay, until it clicks into place and slide the battery-lock latch towards the lock position.
    • Make sure to replace all screws and ensure that there are no stray bolts.
结论
另外一个人完成了本指南。
Devyn Johnson
于12/24/17注册
232 声望
创作了2篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 15
总计 601
