跳转到主内容
Dell Inspiron 910 Keyboard Replacement
你所需要的
  1. Dell Inspiron 910 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
  3. Dell Inspiron 910 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Lift up the keyboard using your fingers or a plastic opening tool.
    • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
    • Disconnect the cable by sliding the connector ears outward.
结论
2等其他人完成本指南。
Kyle Beekman
于04/05/12注册
144 声望
创作了6篇指南
团队
Cal Poly, Team 14-10, Forte Spring 2012 Cal Poly, Team 14-10, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G10
5 名成员
创作了7篇指南
一条评论
Impossible if you don’t have this tutorial.
2 Photos!
Perfect!
WildBill - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 1,826
