当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Be careful of the wire attached to the underside of the hinge cover.
Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
The keyboard should be easily removable at this point.
Flip the laptop over and remove the indicated screws.
Flip the laptop back over.
Find the two places where the display module is attached to the base of the computer.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
