简介
Follow this guide to replace the top case of the Dell Inspiron 8600.
配件
无需配件。
  1. Remove the battery from the bottom of the laptop.
    • Remove the battery from the bottom of the laptop.
    • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
    • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
  2. Locate the small opening at the upper left of the top blue panel which houses the power button. Use a spudger to lift up and remove the blue panel. Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
  4. Flip the laptop over and remove the indicated screws. Flip the laptop back over.
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  6. Disconnect the video card from the display module by gently lifting upwards on the black tab.
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  7. Lift the display module directly upwards from the base of the computer. Lift the display module directly upwards from the base of the computer.
    • Lift the display module directly upwards from the base of the computer.
  8. The display module has been removed.
    • The display module has been removed.
  9. First, remove all tabs using a flat head/ finger. Next, remove all screws using a #1 Philips screwdriver. Pull apart top case from the lower case. It will be quite difficult to separate.
    • First, remove all tabs using a flat head/ finger.
    • Next, remove all screws using a #1 Philips screwdriver.
    • Pull apart top case from the lower case. It will be quite difficult to separate.
  10. Remove all screws on the top of the lcd There all several screw on each side of the LCD. Remove all. There all several screw on each side of the LCD. Remove all.
    • Remove all screws on the top of the lcd
    • There all several screw on each side of the LCD. Remove all.
  11. LCD should remove smoothly.
    • LCD should remove smoothly.
    • The top case will be what remains.
结论
另外一个人完成了本指南。
Perry
于2011年04月12日注册
248 信誉积分
创作了4篇指南
团队
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G22
4 名成员
创作了16篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 2,026
