当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Locate the small opening at the upper left of the top blue panel which houses the power button.
Use a spudger to lift up and remove the blue panel.
Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
You should now be able to completely remove the hinge cover.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
