本指南有最近更改,您可查看未经巡查的最新版本。
简介
We are going to show you how to remove the lower case, how to remove the components, how to put them back in and finally how to attach the upper case back onto the lower case.
你所需要的
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
Flip the laptop over and remove the indicated screws.
Flip the laptop back over.
Find the two places where the display module is attached to the base of the computer.
