跳转到主内容
Dell Inspiron 8600 LCD Replacement
你所需要的
  1. Dell Inspiron 8600 LCD Replacement, Hinge Cover: 步骤 1 中的图像 1,3 Dell Inspiron 8600 LCD Replacement, Hinge Cover: 步骤 1 中的图像 2,3 Dell Inspiron 8600 LCD Replacement, Hinge Cover: 步骤 1 中的图像 3,3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  2. Dell Inspiron 8600 LCD Replacement: 步骤 2 中的图像 1,1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  3. Dell Inspiron 8600 LCD Replacement, Display Module: 步骤 3 中的图像 1,2 Dell Inspiron 8600 LCD Replacement, Display Module: 步骤 3 中的图像 2,2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  4. Dell Inspiron 8600 LCD Replacement: 步骤 4 中的图像 1,1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  5. Dell Inspiron 8600 LCD Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 8600 LCD Replacement: 步骤 5 中的图像 2,2
    • Lift the display module directly upwards from the base of the computer.
  6. Dell Inspiron 8600 LCD Replacement: 步骤 6 中的图像 1,1
    • Now remove the display module.
  7. Dell Inspiron 8600 LCD Replacement, LCD: 步骤 7 中的图像 1,3 Dell Inspiron 8600 LCD Replacement, LCD: 步骤 7 中的图像 2,3 Dell Inspiron 8600 LCD Replacement, LCD: 步骤 7 中的图像 3,3
    • First, remove the plastic tabs that are covering the interior screws.
    • After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
    • Note there are 8 tabs and 8 screws in total.
  8. Dell Inspiron 8600 LCD Replacement: 步骤 8 中的图像 1,1
    • Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
  9. Dell Inspiron 8600 LCD Replacement: 步骤 9 中的图像 1,1
    • Using a Philips #1 screwdriver remove the screws holding the LCD in place.
    • Note there are 8 screws in total for this step, 4 on each side of the unit.
  10. Dell Inspiron 8600 LCD Replacement: 步骤 10 中的图像 1,1
    • Remove the broken LCD unit, and replace with new unit.
结论
2等其他人完成本指南。
Perry
于04/12/11注册
251 声望
创作了4篇指南
团队
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G22
4 名成员
创作了16篇指南
一条评论
which controller board do i have to use for this model ?
bcdoor - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 4,637
