跳转到主内容
Dell Inspiron 8600 Keyboard Replacement
你所需要的
  1. Dell Inspiron 8600 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: 步骤 2 中的图像 1,3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: 步骤 2 中的图像 2,3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: 步骤 2 中的图像 3,3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: 步骤 4 中的图像 3,3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
结论
2等其他人完成本指南。
Perry
于04/12/11注册
251 声望
创作了4篇指南
团队
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G22
4 名成员
创作了16篇指南
一条评论
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
fordsmtack - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 3,876
