当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the battery from the bottom left of the laptop as shown.
Remove the battery before operating on the computer to avoid electrocution.
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Be careful of the wire attached to the underside of the hinge cover.
Pull the small black tab on the right hand side of the laptop.
You have now removed the hinge cover.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与8其他贡献者
于04/13/11注册
186 声望
创作了6篇指南
徽章: 11
+ 8更多徽章
CPSU-GARNER-S11S18G22
4 名成员
创作了16篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 5
总计 3,472
