跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will show you how to remove the CD-Rom Drive and replace it with a properly functioning one.
配件
没有特定配件。
  1. Remove the battery from the bottom of the laptop.
    • Remove the battery from the bottom of the laptop.
    • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
    • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
  2. Locate and remove the screw that secures the CD-Rom Drive.
    • Locate and remove the screw that secures the CD-Rom Drive.
  3. Push the button on the lower right hand side of the CD-Rom drive component. The button should pop out. Then pull out the CD-Rom Drive from there.
    • Push the button on the lower right hand side of the CD-Rom drive component.
    • The button should pop out.
    • Then pull out the CD-Rom Drive from there.
结论
2等其他人完成本指南。
Brian Murphy
于2011年04月13日注册
368 信誉积分
创作了4篇指南
团队
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G22
4 名成员
创作了16篇指南
cuando estoy trabajando la unidad de cd expulsa el disco
Hector Alfonso - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 3,267
