跳转到主内容
Dell Inspiron 7586 2-in-1 SSD Replacement
你所需要的
  1. Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: 步骤 1 中的图像 1,3 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: 步骤 1 中的图像 2,3 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: 步骤 1 中的图像 3,3
    • Flip the laptop over so the bottom is facing up.
    • Use a Phillips #00 screwdriver to remove nine screws from the back case.
    • Insert an opening tool or spudger in the seam between the back case and the body of the laptop.
    • Work your way around the perimeter of the laptop and release the clips that secure the back case.
    • You will hear a clicking sound as the the clips are released and the back case is being removed.
    • Remove the back case.
  2. Dell Inspiron 7586 2-in-1 SSD Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 7586 2-in-1 SSD Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 7586 2-in-1 SSD Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the single screw securing the NVME drive.
    • Once the screw is removed, the SSD should pop up.
  3. Dell Inspiron 7586 2-in-1 SSD Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 7586 2-in-1 SSD Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 7586 2-in-1 SSD Replacement: 步骤 3 中的图像 3,3
    • Gently slide the SSD out of the slot.
    • Make sure to gently pull out the drive to avoid damaging the M.2 slot where you insert the new SSD.
  4. Dell Inspiron 7586 2-in-1 SSD Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 7586 2-in-1 SSD Replacement: 步骤 4 中的图像 2,2
    • Align the tooth edge of the SSD with the indents on the drive socket and gently insert the replacement SSD.
    • Press down on the SSD so the screw hole and drive align.
    • Use a Phillips #00 screwdriver to replace the screw.
    • Don't be scared to push down on the SSD as it should be level with the rest of the components.
结论
2等其他人完成本指南。
Mike03
于03/05/24注册
139 声望
撰写一个指南
团队
CSU Los Angeles, Team 7-1, Grodsky Spring 2024 CSU Los Angeles, Team 7-1, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S7G1
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 35
总计 443
