跳转到主内容
Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement
你所需要的
  1. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: 步骤 2 中的图像 3,3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: 步骤 3 中的图像 1,1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: 步骤 4 中的图像 3,3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
  5. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Memory Modules: 步骤 5 中的图像 1,2 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Memory Modules: 步骤 5 中的图像 2,2
    • Peel back the mylar coverings on the RAM chips on the right side of the system board.
  6. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: 步骤 6 中的图像 3,3
    • Push outward on the two gray tabs on either side of the RAM module.
    • These tabs hold down the RAM modules, which should pop up when disengaged.
    • Gently pull the memory module out of its slot.
    • Be sure to only touch the edges of the RAM module, as the oil from your fingers can damage the components on the face.
  7. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: 步骤 7 中的图像 1,1
    • With the new memory module, line up the notch on the memory with the tab on the module slot.
    • Insert the memory module at an angle.
    • Push down on the module until the locking tabs on either side click into place.
    • If there is no click, reinsert the module.
  8. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: 步骤 8 中的图像 1,1
    • Repeat steps 5-7 for the other memory module.
    • In this laptop, one set of tabs was gray plastic and the other was metallic.
    • When pushing down on the memory modules, make sure you hear a click.
结论
另外一个人完成了本指南。
Brady Kennedy
于09/27/21注册
109 声望
撰写一个指南
团队
Casper College, Team 1-2, Lareau Fall 2021 Casper College, Team 1-2, Lareau Fall 2021 的会员
CASC-LAREAU-F21S1G2
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 22
总计 436
