简介
This guide will walk you through how remove the hinges from the systems board and palm rest of a Dell Inspiron 7573 2-in-1 computer. This guide is useful for replacing a hinge that may be defective or damaged. Complications such as your computer having a hard time opening and closing the screen may be remedied by replacing such hinges.
你所需要的
Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
Using a Phillips #00 screwdriver, remove the 3 mm screw that secures the wireless-card bracket and wireless card to the I/O board.
Lift the wireless-card bracket off of the wireless card.
Disconnect the white and black antenna cables from the wireless card.
Slide and remove the wireless card from the wireless card slot.
Peel off the tapes that secure the display cable and touch-screen board cable to the system board.
Open the latches and disconnect the display cable and the touch-screen board cable from the system board.
