跳转到主内容
Dell Inspiron 7573 2-in-1 Battery Replacement
你所需要的
  1. Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Battery Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 7573 2-in-1 Battery Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 7573 2-in-1 Battery Replacement: 步骤 2 中的图像 3,3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Battery Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 7573 2-in-1 Battery Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 7573 2-in-1 Battery Replacement: 步骤 4 中的图像 3,3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
结论
3等其他人完成本指南。
Kylie Freese
于09/27/21注册
453 声望
创作了3篇指南
团队
Casper College, Team 1-2, Lareau Fall 2021 Casper College, Team 1-2, Lareau Fall 2021 的会员
CASC-LAREAU-F21S1G2
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 57
总计 2,774
