简介
When removing or replacing the WiFi card of the Dell Inspiron 7568 it is important to make sure the laptop it is unplugged and completely turned off. User should also remember to be careful when unplugging and removing the battery. It is recommended that users keep different screw types separated to keep assembly easier. Make sure to uses a Phillips head #1 screw driver. Make sure to work in a static free area with static protection gloves.
工具
配件
没有特定配件。
Remove the wide-brimmed 3mm Phillips #1 screw connecting the Wifi Card.
Remove the Wifi Card.
即将完成!
结论
