跳转到主内容
Dell Inspiron 7568 Hard-Drive Replacement
你所需要的
  1. Dell Inspiron 7568 Hard-Drive Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 7568 Hard-Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Hard-Drive Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 7568 Hard-Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Hard-Drive Replacement, Hard-Drive: 步骤 3 中的图像 1,1
    • Remove the three 3mm Phillips #1 screws connecting the hard drive to the laptop.
  4. Dell Inspiron 7568 Hard-Drive Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 7568 Hard-Drive Replacement: 步骤 4 中的图像 2,2
    • Disconnect the highlighted SATA cable from the hard drive.
  5. Dell Inspiron 7568 Hard-Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the four 3mm Phillips #1 screws of the hard drive. Both sides look identical.
  6. Dell Inspiron 7568 Hard-Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the hard drive (right) from its frame (left).
结论
Elijah Basile
于11/06/19注册
358 声望
创作了4篇指南
团队
IUPUI, Team S1-G4, Stella Fall 2019 IUPUI, Team S1-G4, Stella Fall 2019 的会员
IUPUI-STELLA-F19S1G4
4 名成员
创作了4篇指南
一条评论
Will a 9mm 2.5” SSD fit in these? or can it be forced in? p16 of the spec sheet says “7mm” but I’m not sure if that’s just saying stock configuration just comes with a 7mm drive? or that it only supports up to 7mm?: https://dl.dell.com/manuals/all-products... Any clarification appreciated, thanks!
Blacknova - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 369
