跳转到主内容
简介
By following the steps in this guide one should be able to replace the complete display assembly on the a Dell Inspiron 7568.
配件
没有特定配件。
  1. Remove the ten 7mm Phillips #1 screws on the bottom cover. Remove the bottom cover.
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Remove the four 3mm Phillips #1 screws holding the battery. Unhinge the connector cable to the battery.
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard Doing this will allow one to access the LCD-motherboard connector cables.
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
    • Doing this will allow one to access the LCD-motherboard connector cables.
  4. Unscrew  the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit). Unscrew  the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
    • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
  5. Disconnect the antenna cable (under the left hinge) Disconnect the LCD and Touchscreen display cables under the right hinge. These are a set of two cables. For better image see image two in step one of this guide.
    • Disconnect the antenna cable (under the left hinge)
    • Disconnect the LCD and Touchscreen display cables under the right hinge.
    • These are a set of two cables. For better image see image two in step one of this guide.
  6. Carefully separate the screen from the bottom half of the device.
    • Carefully separate the screen from the bottom half of the device.
结论
2等其他人完成本指南。
Yash Samant
于2017年02月22日注册
373 信誉积分
创作了3篇指南
团队
USF Tampa, Team S2-G2, Lacy Spring 2017 USF Tampa, Team S2-G2, Lacy Spring 2017 的会员
USFT-LACY-S17S2G2
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 3
总计 939
