跳转到主内容
Dell Inspiron 7000 2 in 1 Battery Replacement
你所需要的
  1. Dell Inspiron 7000 2 in 1 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip your Dell Inspiron 7000 2 in 1 laptop upside down to get started. Find the locations of all the 10 screws.
    • Remember to turn the laptop off before you begin the repair.
  2. Dell Inspiron 7000 2 in 1 Battery Replacement: 步骤 2 中的图像 1,1
    • Using your Phillips #00 screwdriver, remove the ten 7.00 mm screws at the bottom of the laptop.
  3. Dell Inspiron 7000 2 in 1 Battery Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 7000 2 in 1 Battery Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 7000 2 in 1 Battery Replacement: 步骤 3 中的图像 3,3
    • Insert the spudger in the gap between the bottom cover and the frame. Then, use it as a wedge and work your way around the perimeter. This will pop open the bottom cover of the laptop.
  4. Dell Inspiron 7000 2 in 1 Battery Replacement: 步骤 4 中的图像 1,1
    • Find the battery located at the bottom right corner of the laptop.
  5. Dell Inspiron 7000 2 in 1 Battery Replacement: 步骤 5 中的图像 1,1
    • Now remove the four 4.0 mm Phillips #00 screws located at each corner of the battery.
  6. Dell Inspiron 7000 2 in 1 Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the battery pin that is connecting the motherboard to the battery by pulling out the pin gently.
    • Remember to safely recycle your old laptop battery.
  7. Dell Inspiron 7000 2 in 1 Battery Replacement: 步骤 7 中的图像 1,1
    • Reinsert the battery pin into the new battery and place it back into its position.
  8. Dell Inspiron 7000 2 in 1 Battery Replacement: 步骤 8 中的图像 1,1
    • Screw the four 4.0 mm Phillips #00 head screws for the battery back into place to make sure the battery is held on securely.
  9. Dell Inspiron 7000 2 in 1 Battery Replacement: 步骤 9 中的图像 1,1
    • Place the cover back onto the laptop and press down on all corners and sides.
    • Make sure to listen for a click to ensure the cover is properly secured.
  10. Dell Inspiron 7000 2 in 1 Battery Replacement: 步骤 10 中的图像 1,1
    • Use the Phillips #00 screwdriver to replace the ten 7.00 mm screws on the back cover.
终点
3等其他人完成本指南。
Neelay Patel
于09/17/21注册
255 声望
撰写一个指南
团队
York University, Team E-31, Melo-Thaiss Fall 2021 York University, Team E-31, Melo-Thaiss Fall 2021 的会员
YORK-MELO-THAISS-F21SEG31
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 42
过去 30 天: 138
总计 5,894
