跳转到主内容
Dell Inspiron 600m LCD Replacement
你所需要的
  1. Dell Inspiron 600m LCD Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 600m LCD Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 600m LCD Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m LCD Replacement, LCD: 步骤 2 中的图像 1,2 Dell Inspiron 600m LCD Replacement, LCD: 步骤 2 中的图像 2,2
    • Using fingernails or a spudger, push any direction on the rubber dots to remove them from the plastic cover.
    • Underneath each rubber dot will be a screw. Remove these screws with the Phillips #00 screwdriver.
  3. Dell Inspiron 600m LCD Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 600m LCD Replacement: 步骤 3 中的图像 2,2
    • Use the IFixit Opening Tool to un-clip the plastic cover, detaching it from the rest of the screen.
    • There are clips about every inch around the right, left, and top of the plastic cover. Be sure that all of them are unclipped.
  4. Dell Inspiron 600m LCD Replacement: 步骤 4 中的图像 1,1
    • Pull straight up on the cover to lift the cover off of the rest of the screen.
    • The bottom part of the plastic is a little sticky.
  5. Dell Inspiron 600m LCD Replacement: 步骤 5 中的图像 1,1
    • Remove four screws (two on each side of the screen) with the Phillips #00 screwdriver.
    • The middle screw does not need to be removed.
  6. Dell Inspiron 600m LCD Replacement: 步骤 6 中的图像 1,1
    • Gently lift the LCD panel off of the base.
    • The LCD is still attached to the computer. Do not pull too hard or you could break the cable.
  7. Dell Inspiron 600m LCD Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 600m LCD Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 600m LCD Replacement: 步骤 7 中的图像 3,3
    • Flip the LCD panel over.
    • Do not touch on or near the back of the panel where it says "Don't Touch." LCD panels contain mercury which is hazardous to humans.
    • Remove the cable by squeezing each side of the connector and gently pulling straight out.
  8. Dell Inspiron 600m LCD Replacement: 步骤 8 中的图像 1,3 Dell Inspiron 600m LCD Replacement: 步骤 8 中的图像 2,3 Dell Inspiron 600m LCD Replacement: 步骤 8 中的图像 3,3
    • Remove the cable at the base of the laptop by pulling up on the yellow tab attached to the cable.
结论
4等其他人完成本指南。
Alex Klimaj
于04/01/11注册
143 声望
撰写一个指南
团队
Cal Poly, Team 10-40, Forte Spring 2011 Cal Poly, Team 10-40, Forte Spring 2011 的会员
CPSU-FORTE-S11S10G40
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 19
总计 6,865
