跳转到主内容
Dell Inspiron 600m Hard Drive Replacement
你所需要的
  1. Dell Inspiron 600m Hard Drive Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 600m Hard Drive Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 600m Hard Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,1
    • The hard drive is located here.
  3. Dell Inspiron 600m Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
  4. Dell Inspiron 600m Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Pull the hard drive tray directly away from the computer. The tray should slide out easily.
结论
7等其他人完成本指南。
Todd
于04/05/11注册
146 声望
撰写一个指南
团队
Cal Poly, Team 10-40, Forte Spring 2011 Cal Poly, Team 10-40, Forte Spring 2011 的会员
CPSU-FORTE-S11S10G40
5 名成员
创作了8篇指南
2条评论
What size is the hard drive, you know, to buy a new one?
Ethan White - 回复
Is it a sata drive compatible or pata? It’s older and most laptops from that year hadn't converted to sata hdd.
physicsguy - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 33
总计 17,221
