跳转到主内容
Dell Inspiron 6000 Screen Replacement
你所需要的
  1. Dell Inspiron 6000 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Screen Replacement: 步骤 2 中的图像 1,1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Screen Replacement, Keyboard: 步骤 3 中的图像 1,3 Dell Inspiron 6000 Screen Replacement, Keyboard: 步骤 3 中的图像 2,3 Dell Inspiron 6000 Screen Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Screen Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 6000 Screen Replacement: 步骤 4 中的图像 2,2
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Screen Replacement: 步骤 5 中的图像 1,1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Screen Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 6000 Screen Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 6000 Screen Replacement: 步骤 6 中的图像 3,3
    • Gently pull the blue tab up until it comes away from computer.
  7. Dell Inspiron 6000 Screen Replacement, Screen: 步骤 7 中的图像 1,1
    • Remove one 4mm Philips #00 screw to completely disengage blue tab.
  8. Dell Inspiron 6000 Screen Replacement: 步骤 8 中的图像 1,1
    • Pull and disconnect the blue tab.
  9. Dell Inspiron 6000 Screen Replacement: 步骤 9 中的图像 1,1
    • Disconnect the black and white wires.
  10. Dell Inspiron 6000 Screen Replacement: 步骤 10 中的图像 1,1
    • Remove four 4mm Philips #00 screws at the hinges for the screen.
  11. Dell Inspiron 6000 Screen Replacement: 步骤 11 中的图像 1,1
    • Separate the top panel of the laptop from the bottom panel.
  12. Dell Inspiron 6000 Screen Replacement: 步骤 12 中的图像 1,2 Dell Inspiron 6000 Screen Replacement: 步骤 12 中的图像 2,2
    • Use the plastic opening tools to remove the six rubber screw covers in the corners.
    • Remove six 4 mm #00 Philips screws located in the corners.
  13. Dell Inspiron 6000 Screen Replacement: 步骤 13 中的图像 1,2 Dell Inspiron 6000 Screen Replacement: 步骤 13 中的图像 2,2
    • Insert the plastic opening tools between the screen holders.
    • Go completely around the screen, separating the screen holders with the plastic opening tools.
  14. Dell Inspiron 6000 Screen Replacement: 步骤 14 中的图像 1,2 Dell Inspiron 6000 Screen Replacement: 步骤 14 中的图像 2,2
    • Remove 12 4mm #00 Philips screws at the perimeter of the screen.
  15. Dell Inspiron 6000 Screen Replacement: 步骤 15 中的图像 1,2 Dell Inspiron 6000 Screen Replacement: 步骤 15 中的图像 2,2
    • Gently lift the screen from the holder.
    • Do not touch the copper part of the bottom side of the screen.
结论
3等其他人完成本指南。
Jacob DeWar
于09/23/14注册
533 声望
创作了3篇指南
团队
USF Tampa, Team 11-1, Blackwell Fall 2014 USF Tampa, Team 11-1, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S11G1
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 32
总计 2,620
