跳转到主内容
Dell Inspiron 6000 DVD/CD Drive Replacement
你所需要的
  1. Dell Inspiron 6000 DVD/CD Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 DVD/CD Drive Replacement: 步骤 2 中的图像 1,1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 DVD/CD Drive Replacement, Removing the DVD/CD Drive Screw: 步骤 3 中的图像 1,1
    • Remove one 4mm Philips #00 screw.
  4. Dell Inspiron 6000 DVD/CD Drive Replacement, Inserting Paper Clip: 步骤 4 中的图像 1,1
    • Open the paperclip as seen here.
    • Insert the paper clip into small hole next to the eject button on the disk drive.
  5. Dell Inspiron 6000 DVD/CD Drive Replacement, Popping Out the DVD/CD Drive: 步骤 5 中的图像 1,1
    • With slight pressure, push the paperclip into the laptop.
    • The disk drive will slowly "pop out" of the side of the laptop.
  6. Dell Inspiron 6000 DVD/CD Drive Replacement, Completely removing the DVD/CD Drive: 步骤 6 中的图像 1,1
    • Using your hand, pull the disk drive out of the laptop.
结论
Kenneth Odum
于09/23/14注册
545 声望
创作了4篇指南
团队
USF Tampa, Team 11-1, Blackwell Fall 2014 USF Tampa, Team 11-1, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S11G1
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 16
总计 1,880
