跳转到主内容
Dell Inspiron 5758 DC Jack Replacement
你所需要的
  1. Dell Inspiron 5758 DC Jack Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 5758 DC Jack Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
  2. Dell Inspiron 5758 DC Jack Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 5758 DC Jack Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 5758 DC Jack Replacement: 步骤 2 中的图像 3,3
    • Slide the battery release switch towards the unlock icon.
    • You should hear a click.
    • Lift and pull the ejected battery to remove it.
  3. Dell Inspiron 5758 DC Jack Replacement, DC Jack: 步骤 3 中的图像 1,3 Dell Inspiron 5758 DC Jack Replacement, DC Jack: 步骤 3 中的图像 2,3 Dell Inspiron 5758 DC Jack Replacement, DC Jack: 步骤 3 中的图像 3,3
    • Remove the one 3mm optical drive screw.
    • Remove the two 8 mm screws.
    • Pry up and remove the access door.
  4. Dell Inspiron 5758 DC Jack Replacement: 步骤 4 中的图像 1,1
    • Remove the one 3 mm screw.
    • Remove the bracket.
  5. Dell Inspiron 5758 DC Jack Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 5758 DC Jack Replacement: 步骤 5 中的图像 2,2
    • Unplug the antenna cables.
    • Remove the Wireless Card.
  6. Dell Inspiron 5758 DC Jack Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 5758 DC Jack Replacement: 步骤 6 中的图像 2,2
    • Unplug the hard drive cable.
    • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
    • Remove the four 8 mm screws.
    • Remove the hard drive.
  7. Dell Inspiron 5758 DC Jack Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 5758 DC Jack Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 5758 DC Jack Replacement: 步骤 7 中的图像 3,3
    • Remove the two 3 mm screws under the battery.
    • Remove the three 2 mm wafer screws under the optical drive.
    • Remove the ten 8 mm base screws.
  8. Dell Inspiron 5758 DC Jack Replacement: 步骤 8 中的图像 1,1
    • Unplug the speaker cable by sliding to the right.
  9. Dell Inspiron 5758 DC Jack Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 5758 DC Jack Replacement: 步骤 9 中的图像 2,2
    • Press in the tabs to loosen the keyboard.
    • Carefully lift the keyboard up and turn it over.
  10. Dell Inspiron 5758 DC Jack Replacement: 步骤 10 中的图像 1,1
    • Unplug the keyboard cable & remove the keyboard.
  11. Dell Inspiron 5758 DC Jack Replacement: 步骤 11 中的图像 1,2 Dell Inspiron 5758 DC Jack Replacement: 步骤 11 中的图像 2,2
    • Slide the DVD optical drive over & remove it from the laptop.
  12. Dell Inspiron 5758 DC Jack Replacement: 步骤 12 中的图像 1,2 Dell Inspiron 5758 DC Jack Replacement: 步骤 12 中的图像 2,2
    • Remove the four 5 mm screws.
    • Unplug the optical drive interposer cable.
  13. Dell Inspiron 5758 DC Jack Replacement: 步骤 13 中的图像 1,2 Dell Inspiron 5758 DC Jack Replacement: 步骤 13 中的图像 2,2
    • Unplug the power button cable.
    • Unplug the touchpad cable.
  14. Dell Inspiron 5758 DC Jack Replacement: 步骤 14 中的图像 1,3 Dell Inspiron 5758 DC Jack Replacement: 步骤 14 中的图像 2,3 Dell Inspiron 5758 DC Jack Replacement: 步骤 14 中的图像 3,3
    • Carefully pry off & loosen the bottom base.
  15. Dell Inspiron 5758 DC Jack Replacement: 步骤 15 中的图像 1,1
    • Remove the bottom base.
  16. Dell Inspiron 5758 DC Jack Replacement: 步骤 16 中的图像 1,2 Dell Inspiron 5758 DC Jack Replacement: 步骤 16 中的图像 2,2
    • Remove the one 5mm screw.
    • Lift the circuit board & turn it over.
    • Unplug the cable.
    • Remove the audio/USB circuit board.
  17. Dell Inspiron 5758 DC Jack Replacement: 步骤 17 中的图像 1,3 Dell Inspiron 5758 DC Jack Replacement: 步骤 17 中的图像 2,3 Dell Inspiron 5758 DC Jack Replacement: 步骤 17 中的图像 3,3
    • Loosen the audio / USB cable.
    • Remove the one 3mm motherboard screw.
    • Lift the motherboard & carefully move it out of the way.
  18. Dell Inspiron 5758 DC Jack Replacement: 步骤 18 中的图像 1,3 Dell Inspiron 5758 DC Jack Replacement: 步骤 18 中的图像 2,3 Dell Inspiron 5758 DC Jack Replacement: 步骤 18 中的图像 3,3
    • Unplug the DC jack cable.
    • Remove the one 3mm screw.
    • Remove the DC Jack.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 1,039
