跳转到主内容
Dell Inspiron 5680 RAM Replacement
你所需要的
  1. Dell Inspiron 5680 RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Power off and unplug the power cable from the computer.
    • You may want to unplug all of the cables and lay the computer on its side to make it easier to work on.
  2. Dell Inspiron 5680 RAM Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 5680 RAM Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove two screws on the side panel of your computer.
  3. Dell Inspiron 5680 RAM Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 5680 RAM Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 5680 RAM Replacement: 步骤 3 中的图像 3,3
    • Remove the side panel from the computer by gently pulling it away from the front of the case and then towards you.
  4. Dell Inspiron 5680 RAM Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 5680 RAM Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 5680 RAM Replacement: 步骤 4 中的图像 3,3
    • Remove the RAM sticks at the right of the CPU by pressing down on the tabs on both ends of the slot.
  5. Dell Inspiron 5680 RAM Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 5680 RAM Replacement: 步骤 5 中的图像 2,2
    • Take your new RAM sticks and line them up with the slots. Push down until the tabs lock and hold them in place.
    • Do not be afraid to apply a little bit of force here. It is recommended to place the RAM in slots 2 and 4 if you only have two sticks.
  6. Dell Inspiron 5680 RAM Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 5680 RAM Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 5680 RAM Replacement: 步骤 6 中的图像 3,3
    • Put the side panel back on, plug the computer in and power it on. You have successful installed your RAM and your computer is ready to run faster.
结论
If your computer does not power on you have not installed the RAM properly. Revisit step 5 and make sure the RAM is completely pushed into the slots.
另外一个人完成了本指南。
Joshua Bandura
于07/02/21注册
133 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 37
总计 1,298
