简介
In this guide, we will show you how to remove and replace the Hard Drive.
配件
无需配件。
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Peel off the tape that secures the hard-drive cable to the palm-rest assembly.
  2. Using the pull tab, disconnect the hard-drive cable from the system board.
    • Using the pull tab, disconnect the hard-drive cable from the system board.
  3. Remove the two screws (M2x3.5) that secure the hard-drive assembly to the palm-rest assembly.
    • Remove the two screws (M2x3.5) that secure the hard-drive assembly to the palm-rest assembly.
  4. Lift the hard-drive assembly, along with its cable, off the palm-rest assembly.
    • Lift the hard-drive assembly, along with its cable, off the palm-rest assembly.
  5. Disconnect the interposer from the hard-drive assembly.
    • Disconnect the interposer from the hard-drive assembly.
  6. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  7. Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  8. Lift the hard-drive bracket off the hard drive. Lift the hard-drive bracket off the hard drive.
    • Lift the hard-drive bracket off the hard drive.
  9. Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  10. Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  11. Connect the interposer to the hard-drive assembly.
    • Connect the interposer to the hard-drive assembly.
  12. Align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
  13. Replace the two screws (M2x3.5) that secure the hard-drive assembly to the palm-rest assembly.
    • Replace the two screws (M2x3.5) that secure the hard-drive assembly to the palm-rest assembly.
  14. Connect the hard-drive cable to the system board.
    • Connect the hard-drive cable to the system board.
  15. Adhere the tape that secures the hard-drive cable to the palm-rest assembly.
    • Adhere the tape that secures the hard-drive cable to the palm-rest assembly.
终点
另外一个人完成了本指南。
Terrence15
于2017年12月18日注册
70,653 信誉积分
创作了442篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
15 名成员
创作了925篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 35
总计 588
