跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Are you trying to enhance your Dell Inspiron's graphics capabilities? Use this guide to replace your graphics card and let the visual splendor begin.
  1. Place the desktop on its side. Make sure to place the computer on a soft but firm surface. Locate and remove the two screws that secure the side panel to the desktop:
    • Place the desktop on its side. Make sure to place the computer on a soft but firm surface.
    • Locate and remove the two screws that secure the side panel to the desktop:
    • Two 1/4" Phillips/slotted combination screws.
  2. Slide the side panel towards the back of the desktop in order to remove it.
    • Slide the side panel towards the back of the desktop in order to remove it.
  3. The graphics card is attached to the back of the desktop. The graphics card is located below the three fans.
    • The graphics card is attached to the back of the desktop.
    • The graphics card is located below the three fans.
  4. Remove the screw that secures the support bracket:
    • Remove the screw that secures the support bracket:
    • One 1/4" Phillips screw
  5. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  6. Remove the support bracket  by lifting up and out. There are tabs that hold the bracket in place, therefor lifting up is an important detail.
    • Remove the support bracket by lifting up and out.
    • There are tabs that hold the bracket in place, therefor lifting up is an important detail.
  7. Locate the push tab that locks the graphics card into place. Push the tab away from the graphics card and towards the fan.
    • Locate the push tab that locks the graphics card into place.
    • Push the tab away from the graphics card and towards the fan.
    • Hold the tab in this position through step 7.
  8. Keep the tab pushed away from the graphics card (see Step 6). Gently lift the graphics card up and out of the desktop.
    • Keep the tab pushed away from the graphics card (see Step 6).
    • Gently lift the graphics card up and out of the desktop.
  9. Remove the two screws holding the VGA ribbon cable to the bracket:
    • Remove the two screws holding the VGA ribbon cable to the bracket:
    • Two M3 hex standoff screws.
  10. Gently unplug the ribbon cable from the header pins. Remove the other end of the ribbon cable from the bracket.
    • Gently unplug the ribbon cable from the header pins.
    • Remove the other end of the ribbon cable from the bracket.
  11. Remove the two screws holding the DVI adaptor to the bracket:
    • Remove the two screws holding the DVI adaptor to the bracket:
  12. Remove the bracket from the graphics card. The job is done! You can now put the better graphics card in and bask in the joy of an enhanced visual experience.
    • Remove the bracket from the graphics card.
    • The job is done! You can now put the better graphics card in and bask in the joy of an enhanced visual experience.
结论
Scott Havard
于2016年06月27日注册
37,927 信誉积分
创作了33篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 8
总计 776
