跳转到主内容
Dell Inspiron 530 DCMF RAM Replacement
你所需要的
  1. Dell Inspiron 530 DCMF RAM Replacement, RAM: 步骤 1 中的图像 1,2 Dell Inspiron 530 DCMF RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Locate and unscrew the two large screws at the back of the computer. Once the screws are removed, the panel on the right side will slide towards the back, and release itself. Lift the panel off the computer to reveal the internals.
  2. Dell Inspiron 530 DCMF RAM Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 530 DCMF RAM Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 530 DCMF RAM Replacement: 步骤 2 中的图像 3,3
    • The RAM will be located on the main circuit board, known as the motherboard. There should be two chips in parallel with each other, both sticking up at a 90-degree angle.
    • On both ends of the RAM chip, there will be white tabs. Push down on these tabs to release the chip from the motherboard.
    • Pull up on the RAM chip to remove it.
    • Do not touch the gold edge of the chip. The oils on your hands can damage it.
  3. Dell Inspiron 530 DCMF RAM Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 530 DCMF RAM Replacement: 步骤 3 中的图像 2,2
    • When inserting the new chip, find the open slot you just took one out of, and then line up the pins on the stick with the holes in the slot, then push down firmly.
    • Once the RAM is in, make sure to push up the white tabs on each side to lock it in place.
结论
另外一个人完成了本指南。
Drew Cunningham
于03/25/15注册
656 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-1, Kish Spring 2015 UMass Dartmouth, Team 5-1, Kish Spring 2015 的会员
UMASSD-KISH-S15S5G1
5 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,001
