跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will demonstrate removing the computer's CD/DVD drive.
配件
没有特定配件。
  1. Place the case on its side.
    • Place the case on its side.
    • Locate and remove the two 13.1 mm thumbscrews.
  2. Slide the side panel towards the back and remove.
    • Slide the side panel towards the back and remove.
  3. Locate the CD/DVD drive in the upper-front corner of the case.
    • Locate the CD/DVD drive in the upper-front corner of the case.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Locate and remove the two cables attached to the CD/DVD drive.
    • Locate and remove the two cables attached to the CD/DVD drive.
  6. Locate and remove the two Phillips #0 7.8 mm screws.
    • Locate and remove the two Phillips #0 7.8 mm screws.
  7. Locate the three plastic tabs connecting the computer's faceplate to the case.
    • Locate the three plastic tabs connecting the computer's faceplate to the case.
    • Gently lift the three tabs to pull off the faceplate.
  8. Pull the faceplate forward and out.
    • Pull the faceplate forward and out.
  9. Completely remove the faceplate.
    • Completely remove the faceplate.
    • Remove the CD/DVD drive by pulling it forward towards the front.
结论
15等其他人完成本指南。
Doug Howe
于2011年10月23日注册
1,801 信誉积分
创作了2篇指南
团队
Cal Poly, Team 6-8, Regan Fall 2011 Cal Poly, Team 6-8, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G8
4 名成员
创作了18篇指南
添加评论
浏览统计数据:
过去的24小时: 4
过去的7天: 8
过去的30天: 58
总计 15,473
