跳转到主内容
Dell Inspiron 530 Replacement of GPU
你所需要的
  1. Dell Inspiron 530 Replacement of GPU, GPU: 步骤 1 中的图像 1,1
    • Remove the side panel, and and and screws that may be holding it in place.
  2. Dell Inspiron 530 Replacement of GPU: 步骤 2 中的图像 1,1
    • Locate the GPU, which should be in the PCIe 16x slot below the fan.
    • Take the old GPU out and put the new GPU in its place.
    • Make sure that you have correctly grounded yourself and that you are using proper tools to reduce the risk of ESD and component destruction. Also make sure that the graphics card that you are using has enough voltage to be powered by your current power supply.
结论
To reassemble your device, reattach any cables and screws that were disconnected and put the cover back on.
3等其他人完成本指南。
bacon
于04/26/16注册
277 声望
撰写一个指南
一条评论
En français on ne dit pas “Processeur graphique” mais “Carte Graphique” car on achète et on change toute la carte graphique.
Hyperion - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 28
总计 1,822
