当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove battery
Open screen so that it lies flat.
Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
Lift keyboard and detach the interface connector.
Take extra care when removing and handling the keyboard. The key caps on the keyboard are fragile and easily come off.
Using a Phillips screwdriver remove the two screws (5.8mm) located at the rear of the laptop.
Detach the screen connector.
Using a Phillips screwdriver remove the four screws (5.8 mm) located at hinges of the screen.
Lift and remove display screen.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与10其他贡献者
于04/14/11注册
201 声望
创作了6篇指南
徽章: 10
+ 7更多徽章
CPSU-MANESS-S11S12G34
4 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 3,676
