跳转到主内容
简介
You will be able to access wires connecting your screen and replace it if needed.
配件
没有特定配件。
  1. Remove battery
    • Remove battery
    • Open screen so that it lies flat.
  2. Starting from the right side of the hinge cover,  use the flat end of the spudger to pry up the hinge cover and gently remove it. Starting from the right side of the hinge cover,  use the flat end of the spudger to pry up the hinge cover and gently remove it.
    • Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
  3. Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard. Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
    • Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
  4. Lift keyboard and detach the interface connector.
    • Lift keyboard and detach the interface connector.
    • Take extra care when removing and handling the keyboard. The key caps on the keyboard are fragile and easily come off.
  5. Using a Phillips screwdriver remove the two screws (5.8mm) located at the rear of the laptop. Using a Phillips screwdriver remove the two screws (5.8mm) located at the rear of the laptop.
    • Using a Phillips screwdriver remove the two screws (5.8mm) located at the rear of the laptop.
  6. Detach the screen connector.
    • Detach the screen connector.
  7. Using a Phillips screwdriver remove the four screws (5.8 mm) located at hinges of the screen. Using a Phillips screwdriver remove the four screws (5.8 mm) located at hinges of the screen.
    • Using a Phillips screwdriver remove the four screws (5.8 mm) located at hinges of the screen.
  8. Lift and remove display screen.
    • Lift and remove display screen.
结论
另外一个人完成了本指南。
May Chauvin
于2011年04月14日注册
201 信誉积分
创作了6篇指南
团队
Cal Poly, Team 12-34, Maness Spring 2011 Cal Poly, Team 12-34, Maness Spring 2011 的会员
CPSU-MANESS-S11S12G34
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 13
总计 3,351
