跳转到主内容
Dell Inspiron 5100 PP07L Memory Replacement
你所需要的
  1. Dell Inspiron 5100 PP07L Memory Replacement, Revealing the memory panel: 步骤 1 中的图像 1,1
    • Flip the laptop on it's back, so that the bottom is facing up.
  2. Dell Inspiron 5100 PP07L Memory Replacement, Screw Removal: 步骤 2 中的图像 1,1
    • Loosen the single Phillips #1 screw.
    • This screw is attached to the panel and cannot be removed.
  3. Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: 步骤 3 中的图像 1,3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: 步骤 3 中的图像 2,3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: 步骤 3 中的图像 3,3
    • Push the highlighted pin outward until the RAM pops slightly out of its socket.
    • Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible.
    • Not seating the new DIMMs correctly could cause the device to refuse to POST.
结论
2等其他人完成本指南。
May Chauvin
于04/14/11注册
201 声望
创作了6篇指南
团队
Cal Poly, Team 12-34, Maness Spring 2011 Cal Poly, Team 12-34, Maness Spring 2011 的会员
CPSU-MANESS-S11S12G34
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 4,519
