跳转到主内容
Dell Inspiron 5100 PP07L CD Drive Replacement
你所需要的
  1. Dell Inspiron 5100 PP07L CD Drive Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove battery
    • Open screen so that it lies flat.
  2. Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 2 中的图像 2,2
    • Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
  3. Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
  4. Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 4 中的图像 1,1
    • Lift keyboard and detach the interface connector.
    • Take extra care when removing and handling the keyboard. The key caps on the keyboard are fragile and easily come off.
  5. Dell Inspiron 5100 PP07L CD Drive Replacement, Screen: 步骤 5 中的图像 1,2 Dell Inspiron 5100 PP07L CD Drive Replacement, Screen: 步骤 5 中的图像 2,2
    • Using a Phillips screwdriver remove the two screws (5.8mm) located at the rear of the laptop.
  6. Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 6 中的图像 1,1
    • Detach the screen connector.
  7. Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 7 中的图像 2,2
    • Using a Phillips screwdriver remove the four screws (5.8 mm) located at hinges of the screen.
  8. Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 8 中的图像 1,1
    • Lift and remove display screen.
  9. Dell Inspiron 5100 PP07L CD Drive Replacement, CD Drive: 步骤 9 中的图像 1,2 Dell Inspiron 5100 PP07L CD Drive Replacement, CD Drive: 步骤 9 中的图像 2,2
    • Flip to the back side of the laptop.
    • Remove thirteen screws (8.6mm).
    • If battery has not yet been removed, remove it now and remove single silver-colored screw at top of empty battery bay.
  10. Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 10 中的图像 1,2 Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 10 中的图像 2,2
    • Remove one screw (8.6 mm) on metal plating.
    • Remove the metal plating.
  11. Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 11 中的图像 1,1
    • Remove two screws (5.8mm)
  12. Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 12 中的图像 1,2 Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 12 中的图像 2,2
    • Disconnect cable.
  13. Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 13 中的图像 1,2 Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 13 中的图像 2,2
    • Make sure that single silver-colored screw has been removed from empty battery bay
    • Remove top cover by lifting the edges upward.
  14. Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 14 中的图像 1,2 Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 14 中的图像 2,2
    • Remove CD drive plating screw (5.8mm)
  15. Dell Inspiron 5100 PP07L CD Drive Replacement: 步骤 15 中的图像 1,1
    • Slide outwards to remove
结论
另外一个人完成了本指南。
May Chauvin
于04/14/11注册
201 声望
创作了6篇指南
团队
Cal Poly, Team 12-34, Maness Spring 2011 Cal Poly, Team 12-34, Maness Spring 2011 的会员
CPSU-MANESS-S11S12G34
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 4,429
