Locate all of the screws under your laptop securing the bottom plate. You should see ten little black screws under the laptop and one big silver screw in the battery compartment.
In the battery compartment, you should see a little bit of the silver part of the DVD drive. Use a tool to push the DVD drive out of it's compartment.
You will see little notches on the keyboard. Use an opening pick or a flat-head screwdriver (preferably an opening pick) and insert it into the notch, working your way around the edges of the keyboard until it fully pops off.
Any other cable bands you see you can disconnect, as this is needed to get into the laptop
Thank you for reading!
