跳转到主内容
Dell Inspiron 3552 Memory Module Replacement
  1. Dell Inspiron 3552 Memory Module  Replacement, Removing the battery: 步骤 1 中的图像 1,1
    • Close the display and turn the computer over
    • Slide the battery-release latch to the unlocked position
    • Lift the battery at an angle and remove the battery from the battery bay.
    • Turn the computer over, open the display, and press the power button for five seconds to ground the system board
  2. Dell Inspiron 3552 Memory Module  Replacement, removing memory module: 步骤 2 中的图像 1,1
    • Using your fingertips, spread apart the securing clips at each end of the memory-module slot until the memory module pops up.
    • Slide and remove the memory module from the memory-module slot.
  3. Dell Inspiron 3552 Memory Module  Replacement, Replacing Ram: 步骤 3 中的图像 1,1
    • Align the notch on the memory module with the tab on the memory-module slot.
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
结论
另外一个人完成了本指南。
Jordon Dozier
于02/10/21注册
1,663 声望
创作了12篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,993篇指南
1指南评论
How many slots for ram has it?
Quique G - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
